INFL REST Question
Old Jun 5, 2011 | 01:31 PM
blaznhot's Avatar
Car: 1992 Firebird
Engine: Stock 305 TBI
Transmission: auto / stock
Axle/Gears: Stock
INFL REST Question
The INFL REST light on the dash of my 92 Firebird stays on now instead of blinking 4-5 times and going off. I know it's for the airbag but what's the best solution to fix it? I haven't checked the fuse yet and hopefully that's all it is. Thanks for any info!
Old Jun 7, 2011 | 10:14 AM
blaznhot's Avatar
Car: 1992 Firebird
Axle/Gears: Stock
Re: INFL REST Question
I've since checked the fuse and it's fine. What would make that light stay on???
Old Oct 12, 2011 | 12:41 PM
confucius101's Avatar
i was about to ask the same question lol
did you ever figure it out???
Old Oct 13, 2011 | 10:29 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
It is indicating a fault in the system. Could be ECM (airbag ecm) sensor, short, dirty of loose connection. Someone else will have to chime in on diagnosis, im not familar with ob1.
Old Oct 30, 2011 | 11:21 PM
guitarguy92b's Avatar
Car: 87 ws6 trans am
Engine: 305sbc
camarotucker is correct it has to do with your air bags, something isnt working correctly, mine only does it when i start the car but i had never seen it before so i did some researched found that out. BUT i couldnt tell u where to begin on how to get the light to come off
Old Oct 31, 2011 | 09:04 AM
blaznhot's Avatar
Car: 1992 Firebird
Axle/Gears: Stock
There's a sensor on each side of the frame in the front to make the airbags deploy on impact. They get dirty over time (from what I found out) and will make the INFL light come on and also the air bags wont work. They just have to be cleaned (the easy part) but getting to them VERY HARD. Mine is still on and will be until someday.......
Old Feb 26, 2012 | 08:50 AM
blaznhot's Avatar
Car: 1992 Firebird
Axle/Gears: Stock
I'm pretty sure it's the sensors located in the front on each side of the frame. I haven't had time to mess with it or get it checked out so just riding with the light on. No air bag I would guess but oh well........
RedLeader289
Jan 22, 2016 03:05 PM
Roblyons
Sep 12, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
