Fuel pump fuse keeps blowing?
Old Feb 26, 2012 | 09:12 AM
zz's z28's Avatar
Car: 1987 Iroc Z
Engine: 383 Mini ram
Axle/Gears: borg warner 9 bolt
I have an 87 iroc z camaro.
I keep blowing the fuse labeled FP.
when that happens my voltmeter drops down to about 9.
Headlights dim and everything.
How should i go about diagnosing this?
Old Feb 28, 2012 | 04:29 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fuelish Advice
Most likely the power wire going to the pump is shorted to ground, or the pump is defective.
You can unplug the connector to determine if it’s the wire or the pump.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
