interior lighting
Old Feb 26, 2012 | 12:39 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
interior lighting
I would really love to do a LED light strip in below the rear seats to light up the floor and another strip on the hatch so i can see in it at night. my plan was to link them up on the courtesy fuse, but thought id check before hand in case i should be warned about anything... also i thought of doing a bright strip under the hood to see the engine at night and, useless but for appearance do a LED bulb in both washer fluid and coolant tanks to light them up as well and have those all hooked to constant power with a preasure switch under the hood so whenever it opens they light up. Thoughts? ideas? concerns?
Old Feb 26, 2012 | 12:49 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Re: interior lighting
The LED lighting uses very little voltage, so no issue with drain on the system. The strips are waterproof, but not the connectors. I don't think "in" any of the fluid bottles is a good idea.
Alternately, to switch the lights under the hood, a mercury switch would work.
Old Feb 28, 2012 | 08:55 AM
Dabesiv's Avatar
my idea of in might be different than yours, i planned on it being encased in some sort of water proof capsule and then properly fixed into the plastic with some epoxy to seal it up air tight. i plan on having some trial and error tests before a complete install. my bigger concern was if heat from the engine could mess with the strips at all
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
