Weird Firebird headlight motor issue, stays energized
Old Mar 3, 2012 | 05:33 PM
Mr.84TransAmer's Avatar
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
I'm trying to get this squared away before tomorrow, but basically I bought a reman'd headlight motor for my 84 T/A (3-wire connector). I installed it, plugged the connector in, and as soon as I connect the battery, the motor gets energized, opens the headlight, and STAYS energized, and the headlight switch is OFF. It doesn't respond to the headlight switch at all (the light does come on / off though). The other headlight works normal.
I can't tell if the motor unit is the problem, or maybe one of the relays. Any ideas?
Old Mar 5, 2012 | 01:32 PM
Re: Weird Firebird headlight motor issue, stays energized
Turned out to be a bad Motor, defective right out of the box. I bought it online - a rebuilt A1 Cardone headlight motor. Just a heads up for you all.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
