This cant be a factory type setting (vss related)?
Old Mar 4, 2012 | 09:04 PM
rhalpin20's Avatar
Car: TA
Engine: 5.7 CCC
Transmission: Manual
Axle/Gears: 3.70
I am checking voltages at each pin on my carbed ecu when i get to pin 16, which is the vss signal. It is supposed to read 10 volts with KOEO but it reads .05v. i then turn the key off, switch vss buffers, turn the car on and viola, 10v. Turn the key off and then back on, .05v. i then touch nothing but the key, turning it off then on, 10v. with every cycle of the key the voltage flip-flops. Please correct me if i am wrong, but shouldnt it read 10v every time?
Old Mar 4, 2012 | 09:21 PM
rhalpin20's Avatar
Car: TA
Engine: 5.7 CCC
Axle/Gears: 3.70
Re: This cant be a factory type setting (vss related)?
Swapped buffers with another one, problem fixed. 2 bad vss buffers...
Old Mar 4, 2012 | 09:23 PM
rhalpin20's Avatar
Car: TA
Engine: 5.7 CCC
Axle/Gears: 3.70
Looks like i may have spoken to soon, problem is still there...
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
86IROC112
Aug 21, 2015 07:20 PM
fonzie85
Aug 13, 2015 11:50 AM
mx127
Aug 10, 2015 08:13 AM
