Wiring for a 454 BBC in my 92
Old Mar 5, 2012 | 08:15 PM
1Broke_camaro's Avatar
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
plain and simple like it says, im planning on shoving a 454 in my 92. are any companies out there that will mod your existing harness to match the motor so i can still run my 700R4 and keep O/D and keep all my gauges. or any company that makes these setups already i can buy brand new???
or is it a simple thing? i wanna keep the bay as clean as possible since last summer i laid new paint down and she hasnt seen the road on her own power in almost 2 years "Long Story "
Old Mar 5, 2012 | 10:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Wiring for a 454 BBC in my 92
Carb or EFI
Carb requires minimum wiring
Gauges , starter and coil ; you can do yourself
Old Mar 6, 2012 | 04:15 PM
yes but i want to run my stock dash and all. can i just pull all the wiring out of it? i know for my carb setup ill need very VERY little to run the motor itself but i wanna make sure everything that is supposed to work does lol.
maybe im looking to much into it idk.
Old May 10, 2012 | 09:40 PM
charger69black's Avatar
I did the swap in my 91 and all of my factory gauges are working good. just lable the harness connectors before you remove them. and transfer the sensor like oil pressure and coolant temps, and fan switch sensor. i didnt use the secondary air and a/c connectors. as for the trans get a tps kit for the carb and also install the map sensor and your trans will shift properly. but may not last long with the added power
Old May 10, 2012 | 10:14 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
should be,plug and play. was going to do the 572 with Ramjet. and at the time GM tech line was working with me on it. it just took way to long on getting the ramjet efi/tpi intake.
and so i did a 427.
but all the rest was plug and play.
as for the 700r4 do the upgrade to the 5 pinon planets, at min.
MustangBeater20
Oct 29, 2022 09:20 PM
Kaweh
Aug 19, 2015 07:06 PM
sreZ28
Aug 14, 2015 07:48 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
