ac compressor
Old Mar 13, 2012 | 06:12 PM
JAKES1963's Avatar
Car: 1992 camaro z28
Engine: 305tpi
Transmission: 5speed
ac compressor
can i put my ac on a toggle switch, replaced 305 tpi with a 383 carbed stoker[ no more computer]used most of original harness
Old Mar 13, 2012 | 06:37 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: ac compressor
You can but I wouldnt recommend it. If you did that, the compressor would run all the time and without knowing what the pressures are in the system, you could iceberg the system or have a catastrophic failure. That what the low pressure cycling switch and high pressure switch is for. To keep the system running properly. Also, if you dont run the cooling fan when the system is operating, the pressure will get so high that it will vent freon out the relief valve or worse, blow something up.
Galaxie500XL
Feb 1, 2020 04:53 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
