Engine runs after turning off ignition few seconds
Old Mar 14, 2012 | 07:16 PM
viperstang's Avatar
Hi,
I have an 87 TA with a 350 carbed manual fuel pump, electric fan. I hooked up wiring for sub amp and it melted and shorted out on the manifold. It blew a whack off fuses which i replaced now the engine will run a few seconds after I turn off ignition switch. It seems to run ok just doesnt shut off immediately like it used to and is annoying me. Any ideas thanks in advance. I just got this car so I am unfamiliar with what happened to the wiring when they swapped the motor to an older 350 vette engine from the original 305 tpi automatic
Old Mar 15, 2012 | 08:10 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Engine runs after turning off ignition few seconds
the most common cause is wiring the electric fan to the ignition system.
when the fan looses power, it acts like a generator supplying enough power to the coil to keep the spark going for a few seconds.
running the fan off the ignition also robs the the ignition system of power and can kill the ignition module.
use a relay to supply the fan with power from the battery.
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 9, 2015 05:27 PM
