idle rpm drops when power is drawn?
Old Mar 18, 2012 | 11:21 PM
aroc256's Avatar
Car: 1988 firebird formula
Engine: 5.0 tbi
Transmission: 5spd std
Axle/Gears: stock
when i am parked and the engine is idling, if i turn on my headlights or my heater or both, the engine rpm will drop like its straining under the load of the power being drawn. it will sometimes recover to the normal idling rpm but often goes back up but a few hundred rpm lower the normal.
any ideas?
aroc256's Avatar
Engine: 5.0 tbi
Axle/Gears: stock
Re: idle rpm drops when power is drawn?
its a 1988 305 tbi by the way
Old Mar 19, 2012 | 12:04 PM
zombienerd's Avatar
Car: 1982 Firebird Base
Engine: 2.8L V6
Axle/Gears: Stock
How is your Amp gauge looking (if you have one) Alternators require extra engine power as they produce more current. If your alternator is severely worn, it could be needing extra torque to keep it producing the required amperage.
If your alternator is new, or in top shape, there may be idle control issues that cannot cope with the strain. I am no expert on that particular setup, however.
Old Mar 20, 2012 | 12:05 AM
aroc256's Avatar
Engine: 5.0 tbi
Axle/Gears: stock
it usually reads at just over 13, im not sure how old the alternator is however
Old Mar 20, 2012 | 07:24 AM
zombienerd's Avatar
Engine: 2.8L V6
Axle/Gears: Stock
Autozone / Advance Auto will do an alternator check for free. If you remove the alternator and bring it into the store, they can tell you whether or not it's producing the proper voltage and amperage, and if it's too worn out mechanically. It's a really neat machine they have.
Old Mar 20, 2012 | 01:37 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
It sounds like its on its way out as its usually the tell tale sign that it is. Doesnt hurt to check it tho
theshackle
Sep 17, 2020 08:26 AM
89GTAOz
May 16, 2020 09:31 AM
mdtoren
Aug 23, 2015 12:52 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
mdtoren
Aug 16, 2015 05:45 PM
