Random No Start (solenoid does engage)
Old Mar 22, 2012 | 09:05 AM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
I have a random no start problem. The solenoid will click but it will not turn over. Go under the car and jump the terminals and it will turn, and then the key will work again for "X" amount of times
This has happened on 3 starters, the stock one and 2 Summit High Torquw mini starters. All of it has happend with in 4 months but thats only 10 to 15 days driving.
If it were a VATTS problem the starter wouldnt even click, and 3 bad starters however likely that could be I doubt thats the problem
Wires are being installed tight
Im at a loss so please
Old Mar 22, 2012 | 04:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Random No Start (solenoid does engage)
Im at a loss
Would appear you have voltage drop ( bad wiring / connection/etc ) in the starter wiring to the solenoid so it doesn't have enough " grunt" to throw the solenoid out.
The fact it works fine when you apply 12V direct off the batt terminal shows a loss somewhere between Ign switch and the starter
Old Mar 22, 2012 | 05:20 PM
89RS_82Z's Avatar
I was talking about jumping the terminals on the starter itself, does the same still apply???
Old Mar 22, 2012 | 08:05 PM
utilityguy2's Avatar
If it clicks but does not engage, sure sounds like the solenoid or starter is bad. have you tried tapping with a hammer when in no start state?
Or it could be that you are not getting a full 12 volts from the ignition switch. Could also be Starter enable module relay but if solenoid clicks, probably not.
Old Mar 22, 2012 | 08:16 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
And the large terminal on the starter gets it's power from where?
You say starter works when it gets full 12V so you have a problem with your wiring back to Ign switch.
Put a DVM on the purple wire at starter and yellow starter wire at switch and see what in line resistance (ohms) you have.
Should be close to zero.
Change to V scale , turn key to START; see what voltage you have between purple and ground at starter
Bet it is not 12V
Old Mar 22, 2012 | 08:19 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by utilityguy2
If it clicks but does not engage, sure sounds like the solenoid or starter is bad. .
Nope
When jumpered direct to 12V as he has done it still would not work if either were bad
Old Mar 22, 2012 | 08:20 PM
89RS_82Z's Avatar
Yeah but 3 starters bad?
Are you talking about a full 12v to the activate terminal of the starter?
Where is the starter module relay?
This just has me so stumped A screwdiver across the solenoid terminals will turn it over, then it will key start, sometimes a few times, none, or 20 times. I feel the solenoid is strong, when it "clicks" its very loud and solid sounding.
Old Mar 22, 2012 | 08:23 PM
89RS_82Z's Avatar
Bet it is not 12V
No i was just talking about jumping the terminals on the solenoid never running a jumper wire to the switch on the solenoid
I will have to check the voltage going to the purple wire
Old Mar 22, 2012 | 08:33 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I know what you are talking about.
Using a screwdriver across the terminals is exactly the same as running a wire from batt POS terminal
direct to small terminal on starter.
FULL 12V VOLTS at solenoid
No drop in voltage from bad connections , dodgy wiring , worn contacts in relay or Ign switch , etc
That is why you know you have a problem with the in car wiring ; not the starters themselves
Old Mar 22, 2012 | 08:42 PM
89RS_82Z's Avatar
we may be having a breakdown in communication
this is the terminals I ran the screwdriver across to start it in a pinch
Sorry if im mis communicating with you
But I do believe now after talking to you there could be the problem with the purple wire somewhere
Old Mar 22, 2012 | 09:47 PM
Nope
What? If starter has bad brushes, solenoid would of course click but starter not turn. Very common with older starters. If hit with hammer and then works starter needs replacement. (jars brushes) Contacts in solenoid could also be bad. would click on engagement but no power to starter then either. Just saying after 40 plus years in the business. 89 RS if you jump between large post on solenoid and small post to side of solenoid does it crank? You haven't yet ruled out the solenoid as being bad.
Old Mar 23, 2012 | 03:14 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
OK
When most on here say they
"jumped the starter terminals"
they are referring to jumpering top power terminal to the small (S) terminal so the solenoid operates as it should and starter actually works to start the engine ( if it is functioning correctly )
What you are doing ( bypassing the solenoid contacts ) only confirms that the motor rotates
Disregard all my previous comments ( although I find it doubtful to get 3 starters with a identical problem )
Old Mar 23, 2012 | 03:18 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Same problem on three different starters?
Old Mar 23, 2012 | 12:14 PM
Yes, I know it doesn't sound reasonable. One thing I have learned though is to rule out the basic stuff before jumping to the hard stuff. Not everyone can perform or understand the more complex systems of the vehicle. We do know that the starter itself will crank the car. But all he gets is a click of the solenoid if trying to start by the key. First test should always be, jump, as you said, positive terminal 12 volt to ignition terminal of starter, if it cranks, that rules out the solenoid. We now know the starter/solenoid is not the problem and we need to move further into the testing procedures. I also believe it is a problem elsewhere but skipping the basics is bad policy in my opinion.
Old Mar 25, 2012 | 10:34 PM
89RS_82Z's Avatar
Ok I got 12.7 v to both the power and to the switched on the solenoid.
My only thought is there is a weak spot in the battery cable that maybe be pinched or something and randomly not getting full contact.
This one is just so messed up. I do not understand what the problem could be
Old Mar 26, 2012 | 12:40 PM
Then the starter should work unless it really is bad. One thought, is the motor properly grounded? No or bad engine ground could also cause this. Try running a jumper cable battery negative to starter. but I think you did say it cranked when jumpered it between two large posts see that may rule that out also.
Old Mar 26, 2012 | 02:49 PM
89RS_82Z's Avatar
I have a 4 gauge wire to ground the engine ...... I'll double check it
Old Mar 29, 2012 | 06:38 AM
mitchs1989iroc's Avatar
Car: 1989 chevrolet camaro iroc-z28
Engine: 5.0
i have a 1989 iroc-z with a 305 standard. last year before i parked it, every so often it would not start. i put the key in push in clutch turn the key and nothing .. all the lights came on.. but no clicks or nothing. sometimes if i tried it for a bit. or just let it sit. it would b fine and start sometimes. i would give er the ol push start. i was wondering if anyone has any ideas on how to fix it or what the problem might be. thanks
Old Mar 29, 2012 | 03:23 PM
89RS_82Z's Avatar
Clutch interlock ...... Maybe Vats system if the security light does not come on. Maybe a bad solenoid , doubt its a dead spot in the starter since there is no clicks
jklein337
Sep 19, 2018 06:23 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
TheExaminer
Aug 26, 2015 04:59 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
