Crazy VSS, Help!
Old Mar 22, 2012 | 03:33 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Crazy VSS, Help!
I've been getting an intermittent VSS issue. Sometimes my speedo jumps all over when the car is in park. It seems to be fine in gear and will stay at 0 if I am on the brake. Once I put it back into park it's bounce every where from 0-70mph. This shows on the speedo as well as the datalog in Tuner Pro. I've already changed out the VSS, VSS Buffer and Cluster.....HELP!
Old May 17, 2012 | 07:15 AM
cwv2's Avatar
Car: 1991 Chevrolet Camaro Z28
Engine: T.P.I. 305
Transmission: 700 R4
Axle/Gears: Richmond 3.73
Re: Crazy VSS, Help!
I had a 700R4 in a blazer that was doing the same thing. After much headache and frustration I found that it was a ground problem.
Not sure that is your problem, but mine was acting the same way and thats what my problem was.
Old May 17, 2012 | 07:39 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Mine did the same thing and it was a ground issue in mine.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Zell1luk
Sep 29, 2015 10:36 AM
