3rd Gen OBD1 Management Scanners
Old Mar 25, 2012 | 11:46 AM
hemicudakidd's Avatar
Car: 1970 Plymouth Hemi Cuda
Engine: 426 Hemi
Transmission: A833 4 Speed
Axle/Gears: Dana 60
Hi,
I have an 88 Trans Am GTA and a 92 Camaro 25th anniversary car.
They both have the OBD1 plugs in them. I also look after some customer's 3rd gen F body cars as well.
Where would i be able to buy an OBD1 scanner from for codes and turning out engine lights and service lights etc?
Thank you in advance
Greg
Suffolk, England
Old Mar 25, 2012 | 11:55 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 3rd Gen OBD1 Management Scanners
On your desk. All you need is a paper clip.
http://www.austinthirdgen.org/index.php?pid=27
Old Mar 25, 2012 | 12:16 PM
Engine: 426 Hemi
Axle/Gears: Dana 60
Thank you for that.
That site seems to be down right now but i'll check back there in a bit.
Thank you again.....
Greg
Old Mar 26, 2012 | 03:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Clip Tip
A paperclip will retrieve codes, however a scanner will of course do that plus monitor, record, and playback data, allow you to see immediate results to performance adjustments, etc.
The
Equus 3140 will do the above and is also setup for OBDII.
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
Old Mar 26, 2012 | 06:07 PM
mrrman's Avatar
I couldnt get the paperclip thing to work on my car...not sure if it has to do with it having a digital dash or not... I have a CP9145 Actron scanner and waiting for the right cable to arrive
Old Mar 27, 2012 | 10:49 PM
duffer26's Avatar
Car: 92 RS
Transmission: auto
i'm geting a old MT2500 from the strapon guy for a good price with all the cards and cables
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
Electro_X
Aug 19, 2015 07:59 AM
