Blowing fuses when in OverDrive 700r4
Old Mar 27, 2012 | 08:24 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
i just put a rebuilt trans in my IROC and the first time out and some of my gauges stoped working and when you would have the lights on it would be making the beeping sound even with the car running well i figured out its was the gauges fuse so i put a new one in.. then i went for anouther drive and it was doing just fine until i shifted it into over drive right as it hit overdrive the gauges took a crap and the beeping came back... i cant think of any reason why overdrive would cause fuse failures. im either gonna have to just drive around in D or carry extra fuses so i can check my gas level. anyone have any ideas why overdrive is causeing this?
Old Mar 27, 2012 | 10:54 PM
duffer26's Avatar
Car: 92 RS
Transmission: auto
Re: Blowing fuses when in OverDrive 700r4
make sure the plug is in the trans case the corect way they can be put in wrong and cause a short
Old Mar 28, 2012 | 01:45 PM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
the plug is in the trans but when i put the tranny back in i had to re connect the 3wires i know i got one of them right, but the other two could have possibly got mixed up
3rd gen money
Oct 11, 2019 09:57 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
Fanatic1074
Oct 2, 2015 03:47 PM
92projectcamaro
Sep 29, 2015 07:07 PM
6998poncho
Sep 25, 2015 02:56 PM
