gauge cluster problems
Old Mar 28, 2012 | 11:14 PM
ROCmy86's Avatar
Car: 86 IROC
Engine: 355 Stealth Ram
ok so im new to the forum and a proud new owner of an 86 iroc. that being said the car i bought pretty much sat for the past ten years in a garage. One of the bugs i found while trying to wake her from her 10 year nap is that the gauges seem to be out, i have dash lights just not properly functioning gauges. for example my tach says my car idles between 35-4500 rpm, my fuel gauge is stuck on holy **** your full, my battery volt meter doesnt work, i believe my temp gauge works still and i think my oil pressure still works as well as my speedo. does anyone know if this is fixable or am i looking at buying a new cluster???
Old Mar 28, 2012 | 11:35 PM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
Re: gauge cluster problems
https://www.thirdgen.org/forums/elec...ach-fixed.html
I read this n saved it.. Never tried it but in theory - it should work..
Good luck
Old Mar 29, 2012 | 12:44 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Redline gauges.com they restore and re-build gauges. They do whole clusters of many other GM cars and probably do ours also. They are very good. I saw them on a TV show a few years back and they did a 70 SS Chevelle and 67 427 Corvette gauge re-do and they looked brand new and were re-calibrated.
Old Apr 2, 2012 | 04:21 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Rage
Here’s how to test the fuel gage.
Remove the sender wire going to the gage.
Tape the bare end of the sender wire and put it aside.
Use a potentiometer with a value of 100Ω or the closest you can find.
Connect one end the potentiometer to the gage from the location you removed the sender.
Connect the wiper of the potentiometer to ground.
Turn the key to RUN.
Slowly adjust the potentiometer from 0Ω to 90Ω.
If the gage is bad it will exhibit the problem you have.
If the gage is good it will display a smooth transition from one end of it’s range to the other.
Therefore the problem is with the sender or wiring going to it.
You can use a loose potentiometer, or you can throw together a quick little panel like this one.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
