fuel pump wiring
fuel pump wiring
i have an 84 camaro that i bought a few days ago. the car has been sitting around for a year.i had to replace my fuel pump today so i made a trap drop above the tank. i have the fuel assembly out and everything and i replaced the fuel pump. so i connected it to the wiring harness just to make sure thier were no electrical problems, but there is an electrical problem cause the fuel pump doesnt make any noise, to make sure the fuel pump was connected right i connected the wiring from the fuel pump to a battery just sitting in my garage and the fuel pump works by doing that. the fuse is fine
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: fuel pump wiring
take a volt meter and see whats goin on with the harness from the body to make sure its sending power
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Pump Slump
There is a Fuel Pump Prime Connector for testing the aforementioned.
It’s located near the right rear of the engine compartment.
It’s a one wire (18 AWG red wire) connector poking out of the harness.
It’s not plugged in to anything.
Apply power and listen for the pump.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Happy Racing!
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
