dash lights and buzzer
Old Oct 16, 2011 | 03:27 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
why do they come one when I depress brake pedal...where to look?
some help is needed
thanks
Old Oct 17, 2011 | 01:40 PM
dodgeram106's Avatar
Re: dash lights and buzzer
Thats what mine was doing to and all my running light's were coming on to when I hit the brake pedal.And when I turned the lights on my brake light's would stay on.I just bought the car 3 day's ago and found one bad brake light bulb and one wrong bulb in the other socket.I changed them both and everything works fine so just check your bulb's.....Tim.
Old Oct 17, 2011 | 03:33 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
bad bulbs or bad/missing grounds can cause it. basically the electricity takes the path of least resistance, leading to things lighting up/going off when they shouldnt.
Old Oct 17, 2011 | 05:49 PM
gscz28's Avatar
Car: 89 iroc
I literally woke up thinking about this at 3am....and had the same thought.
yep all fixed..seems when I was putting back together I used the wrong bulbs...
who would've thunk it
all fixed
Old Apr 5, 2012 | 09:38 PM
jlta85's Avatar
hey guys, i have a 1985 ta and i have same problem can you tell me what kind of bulbs i need is it 1157 or 2057
Old Apr 6, 2012 | 04:01 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Bulb Buying
2057’s.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Pilotrick50
Sep 2, 2015 12:48 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
