fuel pump wiring please help!
Old Apr 3, 2012 | 03:41 PM
ttrumbull56's Avatar
i have an 84 camaro that i bought a few days ago. the car has been sitting around for a year.i had to replace my fuel pump today so i made a trap drop above the tank. i have the fuel assembly out and everything and i replaced the fuel pump. so i connected it to the wiring harness just to make sure thier were no electrical problems, but there is an electrical problem cause the fuel pump doesnt make any noise, to make sure the fuel pump was connected right i connected the wiring from the fuel pump to a battery just sitting in my garage and the fuel pump works by doing that. the fuse is fine
Old Apr 4, 2012 | 09:40 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel pump wiring please help!
Originally Posted by ttrumbull56
ii connected the wiring from the fuel pump to a battery just sitting in my garage and the fuel pump works by doing that.
the fuse is fine
So find out if the relay is working or even being turning on.
Check for 12V full time at the relay to run the pump? Fusible link from battery may be blown
Old Apr 4, 2012 | 10:46 AM
ok so where is that fuisble link located? and i ordered a relay
Old Apr 4, 2012 | 06:18 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Have you checked for 12V full time at the relay?
i ordered a relay
You could have tried the identical fan relay next to the pump relay before buying a new one
Old Apr 4, 2012 | 07:19 PM
http://i1271.photobucket.com/albums/...ll56/photo.jpg
heres the set up and i did try to plug it into the fan relay and it doesnt work
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
