Headlight Actuator Help
Old Apr 5, 2012 | 03:12 PM
DannyJohnson's Avatar
Car: 1984 Pontiac Firebird
Engine: Carbureted 2.8 V6
Well, my headlights stopped going up; they go down. Thinking it was the gears inside, I opened one of the actuators up and found all the gears were good.
What else can cause the failure?
The lights used to go up and down for a while then eventually failed.
Sometimes one light wouldn't open, but I could cycle the light switch a few times, and the light would go up.
1984 Firebird
Old Apr 5, 2012 | 03:30 PM
bttrflybird's Avatar
Car: 89' Bandit 2 #104 of 500
Engine: LS1 5.7L
Transmission: 4L60e
Axle/Gears: 3.23 posi
Re: Headlight Actuator Help
i have a simular issue right now my 89 firebird passanger side light struggles to lift up sometimes...if i flip the switch it kind just flops a little bit then eventually lifts up with 1 or 2 tries.
Old Apr 5, 2012 | 06:02 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Probably the isolation relay. I think the 84's used a 3 relay system?
Old Apr 7, 2012 | 08:26 PM
Thanks for the response; where is the the isolation relay located?
Old Apr 7, 2012 | 08:34 PM
85FBTranam's Avatar
The isolation relay is located on the rad support wall, right behind the passenger side headlight (engine side). There are two other relays, one on each fender. These control the headlight motors and are interchangeable. The isolation relay is not interchangeable with the motor relays.
Old Apr 8, 2012 | 05:44 PM
Thanks again, I will check them out Monday.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
