help hotwiring my own car
Old Apr 5, 2012 | 04:53 PM
Naught405's Avatar
Hey so i have this retarded ****ing problem of my key wont turn the ignition lock because of dumb and fail . As a student i have about negative $80,000 to put into my car so I was wondering if any of you guys know a way to functionally hotwire a 1985 camaro (4bbl 5.0L).
Thanks!
Old Apr 5, 2012 | 07:39 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: help hotwiring my own car
Rough way
A wire from batt through a switch to coil POS+ ( pink ),
A wire from starter ( purple ) through push button to battery
Better way
find those wires at the Ign switch plug at base of steering column and connect the power ( batt) wire that is also there to the switches
If you have a elec fuel pump ( early carb engines have a mech pump on the engine )
you also need the new wire to the coil to run to the pump relay
Old Apr 5, 2012 | 08:54 PM
dumquad's Avatar
Car: 82 camaro, 02 tribute
Engine: 360 sbc
Transmission: v6 t5
If you wanted theres a ignition box with a lever going into it, you could remove it from the steering column and use a screw driver to start your car. Ive dont it with mine when i could find the key lol
Old Apr 5, 2012 | 09:53 PM
trafficlightguy's Avatar
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
1st way, use a slap hammer or what you would call a dent puller into your ignition cylinder and pull then use a pliers to start.
2nd way, romove the steering wheel and then remove the cylinder and use pliers to start
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
