89 350 tpi. will an 87 350 tpi harness work?
Old Apr 7, 2012 | 10:17 AM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
i need a new wiring harness for my 89 350 tpi. there is a harness available, but that's from an 87. will everything still work?
Old Apr 7, 2012 | 06:35 PM
Engine: 350 L98/LS2
Re: 89 350 tpi. will an 87 350 tpi harness work?
Someone know?
Old Apr 7, 2012 | 07:22 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I can't remember offhand if 89 was the years GM switched from MAF to S/D.
The harnesses will be similar but, not the same even if it is MAF. The fan (temp switch) wiring changed slightly '88+ and the A/C pressure fan request changed slightly along with the wire colors to them.
'87 uses a different style (shape) relay from '89, also.
No 9th injector for '89.
ECM pinout from MAF to S/D is slightly different and obviously, the ECM is different as well.
That's about all I can think of.
Vintageracer
Jan 10, 2020 05:33 PM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
marcusaw
Aug 10, 2015 08:13 AM
