Left turn signal does not blink
Old Apr 7, 2012 | 11:37 PM
Kevin Lee 487's Avatar
Car: 1999 Trans Am Ram Air
So far I've replaced the bulb and checked the Turn B/U fuse as well as checked the flashers ( The big silver fuses I think right? )
I also checked what I think was the ground ( near the battery, behind the driver side fender. Not the one on top sitting under the hood ) and it wasn't corroded.
Anything common that would cause the 1 signal to not flash?
I'm still learning cars and such but I DO catch on very quickly so please excuse my ignorance on what may be cake to you guys.
Old Apr 9, 2012 | 03:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Turn The Car Around
You say you replaced “the bulb” which indicates it’s only one of the left signals which doesn’t blink.
Is the problem at the front or rear?
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Old Apr 9, 2012 | 04:29 PM
Re: Left turn signal does not blink
Neither will blink. Both the yellow turn signal in front and the tail light stay solid ( The whole left light ). The bulb I replaced was in the front. I'm going to slap myself if it turns out to be the rear end and I never thought of that.
Old Apr 9, 2012 | 04:47 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Could be the switch on the steering colum, "that clicking noise you get when you push it up or down to turn left or right" also have you done any work to the dash area recently?
Old Apr 9, 2012 | 06:08 PM
No dash work. The light itself turns on, it just doesn't blink.
Old Jun 1, 2012 | 07:56 PM
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Im dumb :S
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
