Strange Speedo Issue...HELP
Old Apr 15, 2012 | 08:02 AM
3318RS's Avatar
Car: 1990 RS
Transmission: Built-700R4
Hello to all, I have a "strange" issue with my speedo. It does not read speed or advance the miles until the car warms up/is running for 10 + minutes. I recently changed out to a new cluster because my tach did not work. I eneded up upgrading to LED's & now my tach works, but SAME issue with the newer cluster.
So, I guess it not my cluster, since the one I just replaced does it as well. To summarize, speedo does not read speed or miles until the car warms up, then works PERFECT. At least until the next time the car has sat for a while & is completely cool.....?????
Old Apr 15, 2012 | 11:01 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Strange Speedo Issue...HELP
kinda sounds like the magnet in the sender is loose or
someting and does not rotate untill the tranny warms up
some...Would think that would light the CEL with a VSS
code though.
Old Apr 15, 2012 | 01:40 PM
3318RS's Avatar
Car: 1990 RS
code though.
I will do some trouble shooting & let you know. Where is the sender??
Old Apr 15, 2012 | 01:48 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
it's on the tail housing of the tranny-same place the
cable would connect on a cable driven speedo.
Old Apr 15, 2012 | 04:18 PM
3318RS's Avatar
Car: 1990 RS
Thank you!
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
BWilcox
Sep 20, 2015 12:19 PM
TrevinE
Sep 14, 2015 03:20 PM
