Problems with instrument panel...
Old Apr 18, 2012 | 02:11 PM
Knot814's Avatar
I recently purchased a 91 Firebird, so far everything has been great, few minor things have need to be replaced. No big. But what I didnt notice until a couple of days ago is that my speedo and rpm gauges are not working at all. The backlights as well. --Everything else, turn signals, pressure gauges, volt meter fuel gauge all seem to be working fine. Any suggestions??
Old Apr 23, 2012 | 05:43 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
You’re Wrong Officer, The Speedo Read Zero
Let’s fix the speedo first.
It’s so easy to hit triple digit speeds on an empty highway and get an unjustified ticket.
If you have cruise control, does it work?
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Old Apr 26, 2012 | 10:56 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: You’re Wrong Officer, The Speedo Read Zero
You need to pull the cluster and test the printed circuit board
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
