vats problem how to fix
Ok so I have a issue with secruity on my car the light is always on I've tried the bypass with the resistors test it with the key and still did not wprk. I then check the wires coming from the ignition from the key and noticed I was gettin.the right amount of ohms so I ruled out the keys igntion and wires. The only.way I can get it to start is to try to start it then wait four mins then it'll start right up how do I Fix this
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: vats problem how to fix
Try
Cleaning key contacts,
clean the contacts inside ign switch that read the key ,
get new key cut
then replace ign switch
Car: 90 Camaro IROC-Z
Engine: L98 350
Axle/Gears: 3.23 posi
Is there a safe way to clean contacts in ignition? I have a brand new key and tried it so its not my keys. Its most likely the contacts in the ignition because the lock cylinder looks worn. I have been trying to find a lock cylinder with VATS contacts in them but the ones I find don't say if they are for VATS cars or not. This is the closest thing I found: STANDARD MOTOR PRODUCTS Part # US161L
Car: 91 CAMARO RS
Transmission: 700R
My 91 vert VATS is giving me hell now it wont start at all now. What is process on total VATS delete any help would be appreciated.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
three was to fix the vats issues, one the key resister bypass with soldering in the correct value resister into the harness. Two would be too get a vats bypass frequency module and the third way is to reprogram out the vats in the eprom located in the memcal in the ecm.
Car: 91 CAMARO RS
Transmission: 700R
I found a website of a guy that completely bypasses the system from the output signal from ecm here is website http://newrockies.ca/
Do you think it will work for me im not sure if its a scam or not but 200 bucks to completely remove system sounds good to me.
Car: 1990 IROC
Engine: Lb9
Transmission: M20
http://www.bakerelectronix.com/products_vats/
Best thing you can possibly do with VATS is replace the tumbler set every 2 years if the car is used a lot simple as that. The main problem is the wires on the back of the tumbler breaking or chaffing. I have a 97 camaro and had another Trans am and all I do is replace tumbler every few years and have never had a vats related problem.
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
That gets expensive ever two years... I just did the resistor and have no problems
Street Lethal
Apr 30, 2019 12:14 PM
