1991 gta trans am
Old 05-02-2012, 04:26 PM
Ndb
Ndb's Avatar
1991 gta trans am
I need help with a 1991 trans am gta
5.7 tpi, I have no pulse at injectors .
Was wanting to check wires going intO the ECM
Does anyone have diagram of ECM pins ?
Mainly want to check grounds going to ECM
Old 05-04-2012, 10:57 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1991 gta trans am
do you have spark ? if not icm or distributor pickup coil would be bad.
http://www.gearhead-efi.com/Fuel-Inj...CM-information
Old 05-04-2012, 11:01 AM
Ndb
Ndb's Avatar
Plenty of spark and all ignition parts have been replaced
As well as sensors including oil etc etc, and no vats problem, no light staying on
It is not getting the pulse signal from ECM
Old 05-04-2012, 11:14 AM
Engine: Lb9
Transmission: M20
check the grounds behind the passenger head.
ECM grd D1 Blk/wht
ecm ground D6 Blk/wht
ecm ground D7 Blk/wht
If all of those are good looks like you lost your injector drivers, If these are the original multi-tech injectors the injector coils fail and short out. southbayfuel injectors has some awesome bosch 3 22#hr injectors. If thats not the case looks like you need a new 1227730,16196344 or 16198262
sailtexas186548
Exterior Parts for Sale
02-29-2016 08:40 AM
The_Phoenix
02-04-2016 07:10 AM
stalkier
08-21-2015 01:54 AM
gta power
08-13-2015 06:15 AM
LilHot
South Central
08-10-2015 03:56 PM
Quick Reply: 1991 gta trans am
