car was running then stopped!~
Old May 6, 2012 | 02:29 PM
Braxton16's Avatar
Car: 1992 camaro rs
Engine: 305 v8 stock
Transmission: automatic stock
it was just a regular moring on my way to work. started my car it started up just fine. then i tryed to turn on th ac and everything died just becasue the ac go turned on? now theres no power at all! i put the key in i heard the beeping and thats all no lights no starting and no radio at all? i just bought a brand new battery so i know thats not it plus i just check it and it saws 12.5 so im not sure what to do help!!! its on 1992 rs 305 v8.
Old May 6, 2012 | 03:01 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: car was running then stopped!~
probably a bad battery cable or connection-check where
the pos.cable connects to the starter solenoid and where
the neg.cable connects to the engine. The extra load of
two fan motors and A/C clutch activating opened up an
iffy connection somewhere.
Old May 6, 2012 | 03:05 PM
Braxton16's Avatar
Car: 1992 camaro rs
i just replaced the positive battery cable. maybe i didnt tighten it enough but it has never done this and i replaced it like a month ago.
Old May 6, 2012 | 03:15 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Also check the wires/fusible links that come off the
positive stud on the starter solenoid and go to the
wiring harness-if not loose or broken,they can wick up
moisture and corrode internally-especially if you are in
an area that uses salt/chemicals on roads in winter.
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
