Intermittent blinker fail 91 Formula Firebird
Old May 6, 2012 | 05:04 PM
sonofshin's Avatar
Car: 91 Formula Firebird
Engine: 5.7 TPI
Sometimes when I actuate the left blinker the green arrow light stays lit and the outside lights do not come on. This only happens sometimes. I think it's a relay somewhere, but I don't know where they're located. Anyone?
Old May 6, 2012 | 05:29 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Intermittent blinker fail 91 Formula Firebird
mine did tht but it was because the bulb was dead. the blinker bulb has 2 filaments. one blinks and the other stays running.
Old May 6, 2012 | 05:30 PM
sonofshin's Avatar
Engine: 5.7 TPI
Like I said, it's intermittent. So 50% of the time it operates correctly.
Old May 6, 2012 | 06:20 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
There are a few things I would check if she was mine. The easiest would be the flasher connections, and then you will have to pull the steering wheel and see what is going on with the turn signal switch.
xkingcodex
Feb 12, 2020 07:43 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Jk_Under
Sep 2, 2015 10:59 PM
Linson
Aug 31, 2015 04:52 PM
Randomtask2
Aug 13, 2015 01:57 AM
