AC doesn't engage
Old May 8, 2012 | 07:21 AM
dairy's Avatar
Car: 90 Camaro
Engine: 305 TBI
Transmission: 5 speed
Axle/Gears: 3.42 POSI
AC doesn't engage
When I switch to any vent position they switch and the air will change if I move it from cool to warm but the ac clutch wount engage. The clutch will engage if I jump it using the battery. I was thinking it was the switch in the control unit. Any Idea?
Old May 9, 2012 | 04:04 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Switching Subjects
To find out if the switch is the problem use a piece of wire to jump it for a few seconds.
However if the compressor does not turn on
use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to probe the light green wire on the pressure cycling switch located on the accumulator (the silver can on the firewall).
Is there power there when the key is in the RUN position and the AC controls are set to AC?
Happy Racing!
If We Don’t Get Cawt We Ain’t Cheatin
84LsxZ28
May 17, 2020 02:21 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
sahlomonic
Sep 20, 2015 07:15 PM
corey8084
Sep 17, 2015 02:56 PM
Glowsock
Sep 6, 2015 06:40 AM
