Battery/altanator cables very confused
Old May 8, 2012 | 10:19 PM
SweetblueZ28's Avatar
Ok so the wires on the positive side are in bad shape and i went to the auto store today but the wire they said was a replacement doesn't look right at all now i dont know if the previous owner hacked **** all up and made his own deal or what. but i've looked on oreillys and cant come up with anything that looks like that at all
here are a couple pictures of what is in the car
Attached Thumbnails Battery/altanator cables very confused-img_20120508_164244.jpg   Battery/altanator cables very confused-img_20120508_173824.jpg   Battery/altanator cables very confused-img_20120508_173813.jpg
Old May 8, 2012 | 10:20 PM
Re: Battery/altanator cables very confused
Heres the cable they said was the replacement
If you need better pics or description i can do so
Attached Thumbnails Battery/altanator cables very confused-img_20120508_173949.jpg
Old May 8, 2012 | 10:32 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Try these guys for a nice new heavy duty cable set. A have their cable set on my car right now and they are awesome!!
http://innovativewiring.com/
Old May 8, 2012 | 10:35 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
that replacement looks pretty close to what is on my '82
except mine(possibly original)had a plastic covering
molded around the battery terminal.
Old May 8, 2012 | 10:46 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Their product is so good, I went out and bought a second set of battery cables for my wife's Blazer. I highly recommend innovativewiring.com
Old May 8, 2012 | 10:47 PM
How does it all connect? cause the one in there has four wires running from it one that connects to the post, one that runs to the altanator, and two that run to that black connector...thats where im getting confused...and that second wire on the battery terminal the black one is the one that runs to the starter
Old May 9, 2012 | 12:00 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
sounds like yours is modified from stock-normally the
alternator output wire connects with the battery cable at
the starter batt cable stud,the small wire coming off the
replacement cable is too small to handle alternator
current-you will have to connect that to starter stud or
come up with some other arrangement that can safely
handle the current without getting hot.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
