Upgrading to 140amp Alternator, which wires need to be changed????
Old May 10, 2012 | 02:02 PM
PUNISH3R's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: V8 5.0 305 TBI
Transmission: 700R4 with B&M MegaShifter
Axle/Gears: Gear Ratio: 2.73 Ring Gear: 7 5/8
Ok, I got hands on a PowerMaster #47861 140 amp Alternator and a Optima Red Top battery for my future stereo install. I'm going to install em this weekend. I just wanted to ensure all my ducks were in line.
Alternator and battery are pretty much plug and play...BUT I read on here that when upping to a higher amp alternator you SHOULD do the wires to the alternator and the battery ground as well. Can someone tell me exactly what wires need to be changed and what gauge wire should be used? I think all I should need is Red and Black primary wire? In 6 gauge? Not sure. Can someone break it down to me Barney Style???? I want to grab everything I need at O'Reilly's so I can start early Saturday. Thanks.
Attached Thumbnails Upgrading to 140amp Alternator, which wires need to be changed????-powermaster-140amp-alternator-47861
Old May 11, 2012 | 10:22 AM
PUNISH3R's Avatar
Re: Upgrading to 140amp Alternator, which wires need to be changed????
"...Bueller?...Bueller?...Bueller?..."
Old May 28, 2012 | 09:56 AM
jwills350's Avatar
did you get your answere on the alternator ?
Old May 28, 2012 | 11:19 AM
PUNISH3R's Avatar
Yes Sir. It's running like a Rockstar. Thanks.
eightsixseven
Dec 16, 2024 01:50 PM
jbd1969
Aug 17, 2015 07:06 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
