Heater Control switch
Old May 23, 2012 | 06:21 AM
stubby1962's Avatar
Car: 1989 IROC-Z
Hi All.. On my 89 IROC the heater controls are not working. The blower motor switch works and the hot/cold works. But when I move the selector switch for the heat/vent/AC nothing..stays blowing out the defroster and the AC is not kicking on. Even when I put the selector on AC, the compressor will not come on. Is there anyway that you can check the control switch to tell if it's bad? Thank You and God Bless US All...John
Old May 23, 2012 | 06:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Heater Control switch
Defrost is the default when there's a vacuum leak (which is often at the switch):
https://www.thirdgen.org/forums/elec...ml#post5278772
I'd guess the AC is a separate issue. Perhaps the system requires a charge.
JamesC
Old Jun 3, 2012 | 08:58 PM
stubby1962's Avatar
Car: 1989 IROC-Z
Hi All:
I have since replaced all the vaccum hoses and still will not switch off the defrost. I have even bypassed all the vaccum and hooked it straight to the heater. Still no luck.. Probably the control unit then?? I have looked at the unit, but have not taken it out. How do you disconnect the hot/cold control from it? Thank You and God Bless US All...John
Old Jun 4, 2012 | 06:05 AM
JamesC's Avatar
Follow the link I provide above.
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Todd84Z
Sep 4, 2015 08:02 AM
Ducati900ss
Sep 2, 2015 09:05 AM
lakeffect2
Aug 23, 2015 08:44 AM
