86 Z28 radio, hatch release, locks not working
Old May 26, 2012 | 05:29 PM
anth0nycurtis's Avatar
Car: 1985 Camaro Z28
Engine: 5.0L 305 V8
Axle/Gears: Standard
Hey everyone,
It's been a long time since I've owned an F-Body, I just recently purchased a 1986 Camaro Z28. I was installing the radio and the previous owner cut the harness, so as I was wiring it in and testing I shorted out the Accessory power (Yellow wire) and thought I popped a fuse. I checked the fuse panel and did not see any popped fuses, to make sure I double checked the fuses with a test lamp and confirmed all fuses are good. I then checked the fusible links coming from the starter which are also all good, does anyone have any suggestions as to what I can check to fix this issue?
I later noticed that with the radio being out, the power locks which were previously working now do not work, neither does the hatch release.
Thanks!
Old May 26, 2012 | 09:23 PM
Engine: 5.0L 305 V8
Re: 86 Z28 radio, hatch release, locks not working
Nevermind, figured it out. Thanks anyways!
Old Jun 17, 2012 | 05:44 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
What was the problem?
Old Jun 18, 2012 | 09:37 PM
Engine: 5.0L 305 V8
Turns out it actually was a fuse, I checked every fuse twice over and the fuse looked good but once I took a test lamp to it I found the bad one, replaced it and everything works now.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
