Fast battery drain. ongoing problem for 5 months
Old Jun 1, 2012 | 04:44 AM
davidjr74's Avatar
Car: 1985 Camaro Iroc
Engine: 350 tpi
Still haven't figured it out. Everywhere I go I take off the negative battery cable so my battery won't drain. If I let it sit for even more then a hour my battery will completely drain and it will hurt the battery so bad to where it won't even jumpstart.
Today I took a test light from the negative terminal to the chassis of the vehicle and the light came on. Then I started pulling fuses one by one. After pulling all of the fuses the light stayed on.
So I have no idea what could be causing this battery drain.
I have a 85 Camaro z-28. 350 tpi. Electronic Fuel Injection.
Old Jun 1, 2012 | 07:30 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Fast battery drain. ongoing problem for 5 months
You are still having a problem? I thought you might have got it fixed. Do you have an amp gauge? if so let me know I have had one short out and cause a problem like this.
Old Jun 1, 2012 | 08:32 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
unplug the alternator and see if it still lights up....
Old Jun 2, 2012 | 04:23 AM
davidjr74's Avatar
Engine: 350 tpi
It does. The only thing I can think of doing now is trying to unplug the starter.
Old Jun 2, 2012 | 05:18 AM
1992COUPE's Avatar
Car: 92 RS 25TH ANNIVERSARY All original
Transmission: T5 WORLDCLASS
Axle/Gears: 3.08 OPEN
Sounds like your POS is going to ground, Check your POS cable from battery to the starter.
Old Jun 2, 2012 | 07:08 AM
Edwardgp's Avatar
Engine: 454-350
Yes that is what happened when the amp meter shorted out on me.
Old Jun 22, 2012 | 02:35 AM
davidjr74's Avatar
Engine: 350 tpi
Fixed itself somehow....
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Apr 30, 2019 12:14 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
