Bad rear hatch release, suggestions on replacement?
Old Jun 3, 2012 | 05:58 AM
1 Quick T/A's Avatar
Car: 92 Firebird
Axle/Gears: 3:42
My 92 has the electric release unit, and after 20 years of service, finally gave up. The hatch was open when it stopped working. I'm assuming it just burned up, I'm getting no response when I try to shut the hatch.
Whats the best way to approach buying one? I'd like to just buy a new unit and bolt in, rather than trying to rebuild the old one, unless it's way less expensive, then I'll rebuild. I'm working on a budget like everyone. Are new units even available? Thanks in advance....
Old Jun 4, 2012 | 03:42 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hatch Latch Catch
They’re all rebuilds.
Your fastest pit-stop is to swap it.
I don’t know what your budget is but they’re only $389 from
Top-DownSolutions
.com.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Jun 4, 2012 | 03:48 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: Bad rear hatch release, suggestions on replacement?
I have two, one has the whole housing. Will sell both together in case you need parts. Both Factory. I will add picture's if you like.
Old Jun 5, 2012 | 03:03 AM
1992COUPE's Avatar
Car: 92 RS 25TH ANNIVERSARY All original
Transmission: T5 WORLDCLASS
Axle/Gears: 3.08 OPEN
My 92 rs did the same thing I just unplug the connector at the motor and plug it back in and it worked again.
Old Jun 5, 2012 | 10:34 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Motor may be bad. Very cheap part from 1A with the housing. Easy swap.
http://www.1aauto.com/1A/TrunkReleas...01/335664/1989
Here's how to replace it. Video also made by 1A.
http://www.youtube.com/watch?feature...&v=xSE5Dx4Oa0Y
Old Jun 9, 2012 | 07:25 AM
Car: 92 Firebird
Axle/Gears: 3:42
Okay, thanks. I think the motor went. I unplugged, plugged back in, wiggled the wire connector slightly, no response. The vid will help me through it,
Thanks everyone!
Old Jun 9, 2012 | 10:46 AM
TheGr8erG00d's Avatar
They're not difficult to rebuild on your own. I bought a $100 rebuild kit and rebuilt mine. Works great.
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
mizz0313
Aug 12, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
