troubleshooting crusie contol
Car: 1987 pontiac GTA
Engine: 350 tpi
I have and 87 grand with a 350 I can't get the cruise working I have swapped a controller checked the set switches it has good vacuum to it I can blow threw the brake switch unless depressed I was wondering if someone had ohm readings for the servo or a way to test what I'm getting there thanks
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Grand Scheme Of Things
On the Servo, disconnected, across terminals A & C the Ω must be no than 55.
Across terminals E & C, same deal.
Across terminals B & D, the Ω must be no than 25.
Happy Racing!
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Happy Racing!
irocbirdbuilder
May 21, 2006 01:43 PM
