Right turn signal on, gauges get strange...
Old Jun 12, 2012 | 11:59 AM
Shepp84Z28's Avatar
Car: 1984 Z28, 2004 F-250
Engine: 305 in the Z28, 10-Cyl in the F250
Transmission: 5-Speed in the Z28, F2250=Auto
Hi,
Two issues:
1. Often when I turn my right turn signal on the RPM, Oil pressure, and Battery charge gauges all stop working and kind of pulse with the blinker
2. At night if I have the lights on and try to turn the dash lights up (so I can see the gauges at night) I get a similar behavior as #1 above, gauges start acting weird.
Any ideas?
Thank you,
Shepp
Old Jun 12, 2012 | 12:18 PM
84firebird1996's Avatar
Car: 1991 Trans Am GTA
Engine: LT-1
Re: Right turn signal on, gauges get strange...
Same here when i dim or brighten my dahs lights everything goes wack!
I recently pulled out my dash and reinstalle dit a while ago and now it does that
Old Jun 12, 2012 | 12:19 PM
Engine: LT-1
I know if you remove headlight switch and all the little stuff the gauges wont work at all. at least in my car
Old Jun 12, 2012 | 12:23 PM
Shepp84Z28's Avatar
I don't believe this car has had it's dash pulled out, or the light switch/pull rod. It's all original.
Thanks,
Shepp
Old Jun 12, 2012 | 06:53 PM
Engine: LT-1
Well just a while ago i couldn't figure why mine were jumping. But i found a solution. Under your dash where the codes scanner goes connected there a 10mm bolt with a black ground wire connected there. That is your gauges ground. I moved it to a better pot which is the dash support on the bottom left side. Its a 10mm bolt too. I made the ground longer and placed it there and now all my gauges work and no interference with my lights or dimmer.
Old Jun 13, 2012 | 07:55 AM
Shepp84Z28's Avatar
Very cool, I'll have to check this out over the weekend, thanks man!
Shepp
Old Jun 13, 2012 | 02:47 PM
Engine: LT-1
No problem just let me know what you find out or if you run into problems ill be more than happy to post pics.
Old Dec 29, 2014 | 04:16 AM
firebird phoeni's Avatar
I gotta check the dash lights on my friends car. His dash lights don't light up. I need some advice on it any takers?
Old Dec 29, 2014 | 06:47 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
my bad ...........please delete ................
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
dibella989
Sep 1, 2015 04:12 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
