window problems
Old Jun 15, 2012 | 03:09 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
window problems
For some reason my windows wont go down, iv tried several switches and still no luck. Any ideas?
Old Jun 15, 2012 | 03:25 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: window problems
Did you check for power at the switch? check the fuse? Did they both quit working at the same time?
Old Jun 15, 2012 | 08:08 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: window problems
Yes checked fuses, theyre good. I had a chance to swap out the window switches with olds ones that i know work, and still no luck. I havent had time to look much more into it but i figured id ask for any suggestions on what to do. Also yes they both just stopped working.
P.s. The car is a 87 Gta
Old Jun 16, 2012 | 06:42 AM
stubby1962's Avatar
Car: 1989 IROC-Z
Re: window problems
Did you check for power at the switches? Possibly a bad ground.
Old Jun 16, 2012 | 10:24 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: window problems
I will be tonight i took the door panel off before i left for work. Looks like someone converted the thing to power windows. So god only knows. Iv had it for two yrs with no problem though.
Old Jun 18, 2012 | 09:16 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: window problems
I did notice when trying with the driver side switch it would act as if it was getting power but the window was "stuck". I havnt been able to do much else due to work
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
neekolzun
Aug 24, 2015 04:59 PM
