How do I wire my temp gauge??
Old Jun 16, 2012 | 07:11 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So my temp gauge is really off in my 84 z28 (carbed engine) and I was thinking of going to Autozone and buying one of there $20 temp gauges but I am not to sure to which wires Ide have to tap into to get the right temperature readings. Ive wired a tachometer in the car before is it similar?thanks!
Old Jun 17, 2012 | 08:14 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: How do I wire my temp gauge??
Mech or Elec gauge?
If elec , does it use stock GM temp sender ,
does it require it's own special sender ,( need to install in the head)
does sender come with the gauge ( often not )
Only a matter of running a wire from the sender to the gauge and then hooking up 12V and a ground
rocn7roc
Sep 21, 2021 02:16 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
