Hawks VATS bypass module
Old Jun 17, 2012 | 01:12 AM
toppgunn77511's Avatar
Has anyone used this VATS Bypass Module for 89-2002 Camaro & Firebird, Vehicle Anti Theft System Bypass Module from Hawks? Is it easay to install, is it worth buying?
Old Jun 17, 2012 | 06:56 AM
rodneyrb's Avatar
Car: 1992 Pontiac Firebird
Engine: 04' 5.3 Liter
Transmission: LS1 T56
Re: Hawks VATS bypass module
I havent used it, but there are other ways around bypassing vats without using this module. What kind of project you working on? I converted a 92 bird and used a new pcm which had the vats programmed out.
Old Jun 17, 2012 | 11:18 PM
I have 92 z28 350 5.7 liter, originally it had a 305 tbi but i swapped it to 350 tpi. I bought a complete 350 tpi out of a 91 z28, came with wiring harness, ecm, passkey box. I havent finished yet, but I think i'm gonna run in to a prob with the VATS system
Old Jun 18, 2012 | 07:10 AM
rodneyrb's Avatar
Ah, well, then as you planned, the vats bypass is your answer. I used a new ecm and so with that, tuned out vats. Have you installed the passkey box yet?
Old Jun 18, 2012 | 09:36 AM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
I have used the one from painless in couple cars...has worked everytime super easy to install
Old Jun 18, 2012 | 02:51 PM
Passkey box has been installed, but motor is currently being installed
Old Jun 18, 2012 | 09:57 PM
what if I take the key of the 350tpi engine from the 91 z28 and have the value of the chip read, take that chip value and have it cut onto a new key copying the key cut from the current motor and key cylinder ?
Old Jun 18, 2012 | 10:06 PM
juanillox8's Avatar
Car: TOO MANY
That should work....if the pass key system you are transferring its a known working unit.
Old Jun 19, 2012 | 12:38 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
To clarify a few things:
- If your car was originally a 1992, you have VATS already and if it worked, you do NOT need to change anything, retune your ECM, buy a bypass box or replace the key. The system will continue working as long as you don't remove it from the dash. It interfaces with the ECM vian the in-dash C207 connector.
- If your car had the 305 TBI engine originally, it is unlikely that it is an original Z28. Doublecheck your RPO codes.
Hope this helps.
Lou
Linson
Oct 24, 2025 02:00 PM
$750 L98
Feb 1, 2025 02:25 PM
jaridjohn
Oct 5, 2015 07:01 AM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
