Theres a Ghost in my car
Old Jun 23, 2012 | 11:18 PM
Napaman08's Avatar
I have an 89 Camaro RS 305 TBI (nothin fancy) only thing done was put an aftermarket cam in. Was told that I would not need to chip it and should go right in and work fine.
I recently got the car on the road about 2 weeks ago and have taken it on short adventures finding more and more weird and wacky things.
For starters the engine will occasionally act as if it is starved for gas checked fuel pressure, holding good.
on every other trip it seems that the SES light comes on when driving. Once stopped the car will sometimes idle fine and others act as if starved for fuel. Light remains on at idle regardless. Also when idling rough the oil pressure jumps way up and way down (gauge?) has brand new oil sending unit. Also when idling rough the volt meter will jump and if turn signal on goes up and down as current goes to turn signal.
In addition to that the car will sometimes not start as if the starter is bad, but not getting any click at starter and volt meter reads 11. Let sit for long period of time cranks right up .
And lastly my Tach will only go as low as 5 when idling or sitting and speedo is bouncing crazy.
Boy have I got a lemon or what. If anyone can answer even one of these daunting questions I would greatly appreciate it.
Thanks in advance
Old Jun 25, 2012 | 10:18 AM
Napaman08's Avatar
Re: Theres a Ghost in my car
Man 100 views and not one piece of advice. That sucks
Old Jun 25, 2012 | 12:18 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Sounds like a handful of problems! For one, get your battery checked, seems like that might affect a few of the problems. The oil im not sure about, gauge work correctly?
Also I know how it is posting with no replies!
How big of a cam did you go btw? A huge cam will mess the computer up for sure
Old Jun 25, 2012 | 12:20 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Have you went over all the wiring in the car to make sure nothing has been cut and exposed to create problems? Tested the Batt and alternator?
With that cam I would still look into tuning it as no matter what the cam is not stock and your running a stock tune.
Old Jun 25, 2012 | 02:09 PM
Napaman08's Avatar
This is the cam
http://www.compcams.com/Company/CC/c...?csid=186&sb=2
There may be an issue with the gauges I'm not sure I know that the temp gauge is not working as the needle has fallen off.
Old Jun 25, 2012 | 02:13 PM
Napaman08's Avatar
I haven't gone over it yet was trying to see if maybe it was a fluke thing someone else has experienced. Maybe to find an "easy fix" (ha ha).
Will take and have battery and alternator tested tomorrow and maybe that is the issue.
As far as tuning goes, I am totally green to this how would I go about tuning it?What would you recommend with this cam
Thanks for the insight
Old Jun 26, 2012 | 05:53 PM
GhostBuster08's Avatar
I Ain't afraid of no ghost!!
Old Jun 26, 2012 | 05:54 PM
Have you thought of hiring a Priest?? I think we need an exorcism!!
Old Jun 26, 2012 | 06:04 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
are you serious?
Old Jun 30, 2012 | 11:02 AM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Axle/Gears: 3.42 Detroit locker
Curious to see what anyone would have said about what would be needed as far a tune for that cam choice.
Old Jun 30, 2012 | 12:21 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
go to tbi chips and have him tune you a chip. imho if its not stock id always want it tuned into my computer
Old Sep 17, 2012 | 03:24 PM
amyz28's Avatar
hey i was wondering if u cud help, my ses light goes goes crazy whilst during a normal start up AND when connecting A and B in ALDL port and as lights flickering (as tho theres a bad wire)the engine drops revs, does this mean its ecm problem or electrical, my car 86 iroc TPI 5.0 has been 'broke' for 1 WHOLE YEAR NOW and its killin me im over in scotland and no want wants to work on her plz help heres a vid
p.s ive changes plugs, leads, 02 sensor, coolant temp sensor and thermostat, new battery.car ran perfect till it was out for a hard drive (which wasnt common) my gut feeling is its electrical i cant get any codes
this second vid is with the A AND B bridged, it wont read a code
http://www.youtube.com/watch?v=InNYu...3&feature=plcp
Old Sep 17, 2012 | 03:37 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
make a new thread
Old Sep 17, 2012 | 04:12 PM
amyz28's Avatar
i have but canny go wrong posting Everywhere!!
Old Sep 17, 2012 | 09:35 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Yeah you can; jacking other people's threads is considered bad form because it takes attention away from their problem, and makes further discussion confusing. That's 3 threads I've just read that you've posted the same post on now; at least this one was not fresh. Cudo's for searching at least, but start your own thread.
That said, not sure about your ses light problem, but something sounds awful up front, like alternator bearings or something like that. And it sounds like you're down a cylinder maybe when you rev it.
Old Sep 18, 2012 | 07:48 AM
amyz28's Avatar
i wasnt aware these were the rules? and will post wherever i feel there is someone with similar issues incase they have managed to resolve it and not bothered to post what the prob was, in this case Napaman08 did have a similar issue to my car.
motor is good compression test came back 14 bar +/- 0.5 bar, good and balanced. thanks anyway
Old Sep 18, 2012 | 08:21 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Might be worth your while to check all your grounds.
Old Sep 18, 2012 | 09:05 AM
bucanero's Avatar
Car: 92 Camaro RS, 25th Anniversary
Engine: 305 cid, 5.0L V8, TBI
Transmission: 700R4, 4 Spd Automatic Transmission
I hade similar problems with my 92 RS but I managed to correct most of the problems. The previous owner tried to make alterations because he never understood the electrical components and he thought by eliminating could work but it just worsened. The first thing I did when I bought my Camaro is inspect the fuses and I found out they had the wrong ones installed so I replace with the right ones, I had the battery replaced, new alternator, new stereo and just installed the factory fog lamps on them. I'm saving right now to send it to an electrical specialist to restore the interior wiring and the fan wiring because it was so messed up the speedometer stopped working.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
