electric trunk switch not working, help please
Old Jul 14, 2012 | 02:02 AM
KingsHustleLA's Avatar
Car: 1986 Camaro
Axle/Gears: 411
The trunk switch in my center console is not working i replaced the button but that didn't work, but when i use the key behind the license plate it opens fine. is there any wires or other things i can check? thanks
Old Jul 14, 2012 | 08:53 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: electric trunk switch not working, help please
This diagram should help: http://www.austinthirdgen.org/mkport...wn_release.jpg
You can start by checking that your parking brake is set (on manual cars) or the shifter is in Park or Neutral (on automatic cars).
Hope this helps.
Lou
Old Jul 17, 2012 | 12:35 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I have the same issue. I got a 6speed swap with autometer gages. When I press the hatch button I have my brake light on the dash light up. Wondering if thats normal? I have got it to work in the past but now it doesnt
Old Jul 23, 2012 | 05:17 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hatch Dispatch
If you hear no *CLICK* when you press the Hatch Switch, check the ACC, and GAGES fuses for power on both sides.
Also: when you apply the Parking Brake, does the dash
BRAKE
light illuminate?
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Aug 11, 2012 | 03:50 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
Re: Hatch Dispatch
Im having a similar issue. I have 2 wires that I think go to the hatch. I have a green and a blue. I hook them up and the switch does not work. I just did a T56 swap so do I need to modify the green wire as it doesnt go to the auto shifter... If I use a test light from a ground and touch the same terminal the blue wire is on the hatch works.
Kris
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
The_Phoenix
Feb 4, 2016 07:10 AM
86IROC112
Aug 17, 2015 02:00 PM
Fronzizzle
Aug 9, 2015 01:15 PM
