Hatch motor wire colours
Old Jul 14, 2012 | 09:25 AM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Hi guys,
i repaired my hatch motor a few months ago and its been working great but today i opened the trunk and it raised up fine, but when i went to close it again its stuck up and i could hear a faint clicking or popping from the motor, i touched the motor and it was red hot ! so in a panic i pulled out the connector from the reversing switch.
however i think i pulled it a bit too hard as all the wires came out of the white plug instead, and now im not sure which order they go back in, i wanted to let the motor cool down and then try it again even if its just to get it to go back down and then unplug it so i can close the trunk properly.
heres a picture of mine facing the motor from inside the car, i just stuck the wires back in which way i thought looked right but obviously they might all be wrong so the main power cable with the white plug is unplugged too until i know which way these wires should go
so i just need to know what is the correct order from left to right if possible, thanks.
Scott
Old Jul 16, 2012 | 10:21 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Hatch motor wire colours
left-to right, black, orange, white, blue.
Lon
Old Jul 16, 2012 | 05:32 PM
gta_knight's Avatar
Car: 1987 GTA
awesome, thanks Lon, i plugged everything back in and the motor pulled the hatch down no problem !
although im not convinced so i climbed in the trunk with it closed and unplugged it, the motor must be on its way out if it keeps failing and getting red hot ?
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
madsv1000
Aug 20, 2015 06:45 AM
355sbcTPI
Aug 19, 2015 04:38 PM
mhatfield 14
Aug 15, 2015 10:47 AM
stalkier
Aug 13, 2015 12:59 PM
