power supply to fuse box
Old Jul 14, 2012 | 09:35 PM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
Does anyone now what wire supplies power to the fuse box? I have no power to anything in the car. Won't turn over, no headlights and so on.
Old Jul 14, 2012 | 09:43 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: power supply to fuse box
Red wires going into the cabin through the C100 bulkhead connector by the brake booster, they go over to the junction post near the battery.
Old Jul 14, 2012 | 10:36 PM
mikeirocz1's Avatar
ok thanks. Most of the stock harness has been cut away. no more fusible links. I'm running a carbed 350 and kept everything for the power acc. , interior, lights and so on. This has been done now for about 6 years with no issues. Today I went out to the car and there isn't any power to the inside. All fuse check out and I tried hooking up the red wires from the bulkhead in the engine capartment directly the the battery and still nothing. They were hooked to a remote solenoid, I bypassed the one on the starter to help prevent heat issues on the solenoid. Do you know if the ignition switch is tied into the power wires for the fuse box? If it is bad could it cause this issue? I figured the headlights would at least come on.
Old Jul 16, 2012 | 04:41 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Monster Story; The Missing Link !
Originally Posted by mikeirocz1
…..no more fusible links.
Uh Oh !
It isn’t.
From the factory it goes to a fusible link.
Happy Racing!
I’ll Bump You Once To Move You Over, Next Time I’ll Spin You
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
backtothe80s
Sep 5, 2015 12:39 AM
L98GTA87
Aug 25, 2015 02:23 PM
stalkier
Aug 13, 2015 12:59 PM
