How do I mount an external coil?
Old Jul 15, 2012 | 04:29 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
I'm installing a small cap HEI distributor with a remote square coil. Because of the shape of the coil (it's a MSD-8226), I can't bolt it directly to the firewall like I wanted. I've been searching around for a bracket of some type and I can't seem to find one. Just wondering if one actually exists or if I'm just going to have to fab up my own. Thanks.
Old Jul 15, 2012 | 07:12 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: How do I mount an external coil?
Which engine are you trying to put this on?
Old Jul 15, 2012 | 07:22 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
It's going a 383 stroker with a HSR setup. I have a small cap HEI distributor that needs an external coil. The car is a 1985 Camaro but I swapped out the ECM for the speed density one.
Old Jul 15, 2012 | 08:06 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Well both the later TPI and TBI motors that use that dist/coil setup have brackets for the coil. Perhaps you could get one of those at the JY and find a suitable place to mount it. Or you could use that as a basis to fab your own
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
