Need help installing gauges
Old Jul 15, 2012 | 09:01 PM
Bitchin'Camaro's Avatar
Car: 1991 Z28
Engine: Rebuilt carbed 305
Transmission: 5-speed
I have just purchased a '91 z28 that has a Sunpro CP8090 tri-gauge half installed and sitting under the hood. The water temperature gauge is connected but the oil pressure and voltage gauges are not. I believe all I have to do is simply run a wire from the battery to the voltage gauge but I'm not sure what I need to do to install the oil pressure gauge. Do I have to purchase a new sender or can I use the stock one, what else if anything do I need to purchase and how would I connect it? Any help would be much appreciated.
Old Jul 17, 2012 | 12:23 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Need help installing gauges
voltage just goes to a 12v switched source. Im not sure if you can hook it to a battery or not but you can try
oil pressure you need the fittings for the line, is it mechanical or electric? if its electric you need a sender. you can attach either to the back of the block or just above the oil filter.
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
86IROC112
Aug 17, 2015 02:00 PM
