Replace this wiring
Old Jul 16, 2012 | 07:29 AM
djjon76's Avatar
Car: '84 Trans Am
Replace this wiring
Hi all.
I want (not necessarily need) to replace this wiring. It's only a short piece, but to short for my liking. But whats the Black thing on the wire? If I replace it do I need whatever that is? Ignore the Blue tape, that's just temporary.
Old Jul 16, 2012 | 08:43 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Replace this wiring
Hard to tell with the tape wrapped around it but the black piece could be either:
A) a connector
B) a fusible link (hardwired fuse that once it blows, it must be cut out and replaced)
If you remove the tape, does the orange wire pull out or is it soldered in and cannot be separated? That will tell you for sure.
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
That is your fused link you must keep this. You must incorparate that into your new wiring. I think you can get a new one at the parts store, or make one using a piece of wire three sizes smaller than the wire you are protecting. You can use the one you have there also.
Old Jul 17, 2012 | 12:59 AM
djjon76's Avatar
Car: '84 Trans Am
Cool. I might just extend the Orange wire. Any idea what the Orange wire is for? As far as I can tell, it just goes to a single wire that has something to do with the check engine light. But I could be wrong.
Old Jul 17, 2012 | 05:38 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
There's extra wiring going everywhere. Why so hung up on that particular one?
Old Jul 17, 2012 | 07:24 AM
djjon76's Avatar
Car: '84 Trans Am
The other wires I know where they go and are in reasonable condition and don't have any black block thing on them. Plus this Black one is just a bit too short and I want to replace the battery terminal block.
specialized
Jun 18, 2022 09:26 AM
Derick15
Sep 17, 2016 05:28 PM
marcusaw
Aug 10, 2015 08:13 AM
