Where does this connector go? ['83 v6 2.8l camaro berlinetta engine compartment]
Old Jul 17, 2012 | 07:50 AM
Stalker7d7's Avatar
Car: '83 Camaro Berlinetta
Engine: 2.8L v6 (LC1)
Transmission: A3
First of all, car won't start, no spark.
When trying to figure out why I'm getting no spark, I see this loose wire on the passengers side of the engine. I can't find any place for it to connect to...
Passenger side of the engine.
Where does this connector go? ['83 v6 2.8l camaro berlinetta engine compartment]-yvzoh.jpg
Old Jul 23, 2012 | 05:15 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Conn-Found It
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the primary of the coil when the key is in the RUN position.
Is there power?
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Jul 24, 2012 | 09:37 AM
zombienerd's Avatar
Car: 1982 Firebird Base
Engine: 2.8L V6
Axle/Gears: Stock
Re: Where does this connector go? ['83 v6 2.8l camaro berlinetta engine compartment]
As I stated in the other thread you started, the top picture (Blue connector, green wire) is for the Choke Thermostat. It plugs on the black round part on the rear driver's side of the carburetor. Pull the air cleaner off, and it should be pretty apparent where it goes on the carb. If your car doesn't have it, it may be because someone changed the carburetor.
As for the green connector, my '82 V6 doesn't have one, so I can't help you there.
Old Jul 26, 2012 | 06:11 PM
Stalker7d7's Avatar
Transmission: A3
Re: Conn-Found It
Is there power?
Happy Racing!
On the ignition coil? Yes there is power. But I don't see what that has to do with where the green connector was originally supposed to go to.
db057
Jan 10, 2020 08:55 PM
meeklay812
Oct 1, 2015 03:46 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
