tach not working after carb switch
Old Jul 21, 2012 | 01:11 AM
charlie.803's Avatar
I need help wiring the factory tach after switching to carb.
Old Jul 21, 2012 | 04:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: tach not working after carb switch
What did you do with the factory tach wire?
Old Jul 24, 2012 | 02:55 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
The factory tach wire should have also ran to the coil. Did you hook up all the wires that went to the original coil?
Old Jul 28, 2012 | 12:05 AM
Before I switched over to carb. I have a 6a msd box with a accel coil. after the switch I have the same but had to change the distributor to a msd to work with msd box.The only wiring I did was to buy the pigtail that pluged up to the opposite side on the msd box and went to the msd distributor..The other wires that came off the other end of the msd box went to the computer control distributor which are still in place.
Old Jul 28, 2012 | 10:37 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Connect the factory tach wire to the tach terminal on the msd box.
Old Aug 1, 2012 | 11:06 AM
ok, thanks
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
matthew911
Aug 12, 2015 09:38 AM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
