car will not start
Old Aug 8, 2012 | 07:13 PM
endo666's Avatar
Car: 84 Camaro
Transmission: Stock 5 Speed
car will not start
My car will not start seams to be an intermittent problem. no cranking of engine.
I have a switch that i have to hold to the on position then turn the key to get the car to start (added by previous owner)
one day the car wouldn't start so i jumped 2 wires that hook into a something on the clutch pedal under the dash. I think it is the safety switch. car fired up.
two weeks ago my car wouldn't start. tried jumping the same wires nothing. put the wires back and replaced the starter car still wouldn't start. removed the 2 wires again and hooked them permanently together and the car fired right up.
car will not start again. I kind of wiggled my foot on the clutch peddal and it started to turn over but about half a second to short to start.
Any suggestion?
i want to try to replace the ignition switch is this easy?
Old Aug 8, 2012 | 08:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: car will not start
https://www.thirdgen.org/forums/post...71-post19.html
Old Aug 11, 2012 | 10:21 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Sounds like there's a short in your 2 wires somewhere...
Old Aug 12, 2012 | 03:05 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I dont' know what the two wires are, could be neutral safety, could be ignition. You'll need to pick up a wiring diagram and try and figure it out.
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
L98GTA87
Aug 5, 2015 11:02 PM
