WTF IS WRONG NOW...
Old Aug 13, 2012 | 09:47 PM
xxZ28xx's Avatar
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
WTF IS WRONG NOW...
Okay so I got my car started, got it on the road.. Drives AWESOME..
BUT... The battery keeps getting drained, now everyone is going to be like short!.. Which it may very well be but no its my alternator it almost has to be. Its a 1988 camaro used to be TBI, swapped it back to a carb.. So when the battery dies I can still drive it..
Heres what happens.
Ill drive it newly charged and it sat forever at my work, I go out and start it up fine, perfect, no problems.. Drive it home then I was like damm I need to take my dog for a ride.. About 10 mins driving all my lights dim to barely nothing and the turn signals stop working I barely have any electrical crap.
I have a HEI Distributor and was wandering if this would cause this to happens because my alternator is a REMAN 100 amp... My brother in law said I may need a 130 amp.
Let me see if I have this set up right first. The wire that screws into the back of the alternator goes to the starter, then the one red wire coming from the pigtail goes to the battery... If that's right then my alternator has to be bad.. Can someone give me some insight on this.. Im almost positive its the alternator because when I'm driving is when this stuff is happening I could let it sit for days and start it up and be good.
Please help, need to go to work tomorrow lol.
Old Aug 13, 2012 | 11:42 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: WTF IS WRONG NOW...
Sure sounds like it might be your alternator not recharging the battery while driving.
Charge up the battery overnight and you can have the alternator tested tomorrow at any car parts store for free.
Old Aug 14, 2012 | 02:23 AM
Cat Amanigh's Avatar
Car: 91 RS
Engine: 305 topped w/ Summit Holley Clone
Transmission: 700R4, a placeholder for that T-56
Axle/Gears: 7 5/8, 2.73
99/100 you're gonna go to the store like Lou said, get it tested, find out it's bad, and then, unless you're rocking some serious extra equipment, you're gonna get a new (not reman) alternator at factory amperage or better, because let me tell you, double the radiator fans, a 40,000 volt coil on an HEI distrubutor, and a carb w/ and electric choke isn't making my car act like this.
Old Aug 14, 2012 | 07:09 AM
xxZ28xx's Avatar
Yeah I work at an Advanced auto parts store.. So I got it tested and they said it was fine, but I know its def that. If it was a short It would def at least charge while driving not die completely.. I got home parked tried to start it immediately didn't even attempt to turn over..
The battery in there is A LOT bigger than the original.. so maybe thats the problem, anyway ill chuck this one off a cliff im tired of Fng around I just went and got this one lol..
http://www.jegs.com/i/Powermaster/713/67861/10002/-1 ... Now if this doesn't work ill go with a short then :P..
I appreciate the help guys, at least Im insured and on the road after a year and a half
Old Aug 14, 2012 | 07:19 AM
brando54009's Avatar
Car: 82 firebird
Engine: a few
Transmission: th350
Axle/Gears: wondering this myself
you can have a big battery you just don't want a small one. the big battery just takes a touch longer to charge but not really noticeable. sounds like its a alternator to me also
Old Aug 14, 2012 | 08:30 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
My bet is on the alternator.
Old Aug 14, 2012 | 08:44 AM
xxZ28xx's Avatar
Thanks guys, Ill tell you how it goes when it gets here. Should be here tomorrow!
Old Aug 15, 2012 | 02:43 PM
xxZ28xx's Avatar
Don't you just love jegs? They sent me the right but wrong part because if you click that link it clearly says single wire connector... even if you scroll down they go on to tell you how simple it is. Good thing these people understand I have to work because they sent me a new one for tomorrow and ill have to give them this one back.. so Ill tell you how it goes when I drive it tomorrow.
Old Aug 15, 2012 | 03:13 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Easy way to test your alternator is to start the car and remove the positive battery cable. If the car dies then the alt is not doing its job(charge the battery and keeping the car running). If it does keep the car running it may be an intermittent problem with the energizer in the alt that signals for it to come on. But my bets are with the alt......
Old Aug 15, 2012 | 05:24 PM
Edwardgp's Avatar
Engine: 454-350
Did we find out the problem.
Old Aug 18, 2012 | 09:06 PM
xxZ28xx's Avatar
Yes sir! It was infact the alternator, car runs and starts up perfectly now.. Well except for the un tuned carb.. Ill have to tune it tomorrow.
Plus my manager took my alternator back and I asked for store credit so yup everything worked out in the end Thanks for all your help guys, its appreciated greatly!
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
